Mirror Blind Spots
Nearly caused a pile up joining the A38 today.
Thankfully the driver of the Mini I nearly shoved into the crash barrier was on the ball.
Feeling a lot less complacent now.
I now realise the blind spot is a bit bigger than I had assumed.
Do any of the standard citroen peugeot mirrors neatly assist with this?
Moral of the story?
Look over your shoulder & thank you to the Mini driver.
I bought these for my van: https://www.wilko.com/en-uk/wilko-blind-.../p/0258248
Pretty good for £3 IMHO, you can adjust them for the best angle after you've stuck them on.
My van: 2008 Berlingo 1.6 HDi Enterprise - a bit ratty!
[-] The following 1 user says Thank You to RattyCortina for this post:
  • smutts
Another alternative is to replace the standard door mirror glass with a wide angle glass like this one.
tinyurl.com/5d2aehyr Obviously check carefully to ensure to get the exact right version.
I put one of these on my first B9 Berlingo and it solved the problem for me, my current B9 didn't seem to need it.
Matt
   previous
   2016 1.6 HDi 100 XTR Grey Met
   2010 1.6 HDi 105 XTR Gold Met
[-] The following 1 user says Thank You to Matt Haigh for this post:
  • smutts
triangle light
14-06-2026 09:30 PM
13-06-2026 04:32 AM
Last Post: Jed Clampit
12-06-2026 10:44 PM
My Berlingo Multispaces
11-06-2026 05:21 PM
Last Post: ADarkDividedGem
10-06-2026 10:25 AM
08-06-2026 11:13 AM
Last Post: TGD
06-06-2026 09:50 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
