wheel offset
Finally worked out why I have clearance issues with the rear tyres & wheelarch.
Somebody has fitted wheels with the wrong offset.
Of course they don't have the ET number stamped on them,
so I had to measure them to find out.
I should have 14x5.5 ET24 and what's there is ET35 ish.
So that's 11mm closer to the body.
Wish I'd found out before I bought new tyres,
as if I'd known I need new wheels, I'd have gone for the 15's.
Tyres would probably be cheaper too, as 14" is an uncommon size now.
At least I don't have to go to Chard, yet. Big Grin
Chard?
Don't go there unless you really have to!
(I grew up there...)
Sent from my Redmi Go using Tapatalk
Chard?
It's the birthplace of powered flight, apparently. Wink
Also where one of the rear beam rebuilders has a business.
Birthplace of all those smug Henry Hoovers.
The DFL's, (Down from Londoners) will be arriving in droves too.
Useful to know - the rear beam re-builder bit anyway!
The pie factory is shutting apparently...
Today 05:30 PM
04-11-2026 11:37 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
20-10-2026 06:45 PM
» Replies: 45
18-10-2026 06:46 AM
» Replies: 82
