Threads: 25
Thanks Received: 27 in 26 posts
Thanks Given: 16
6
Had a search through the threads about running a new earth to the steering column to cure a non-working horn. However my horn will only work with the inner (moving) column earthed. Am I missing something, or does that mean the problem is with the horn push contacts? TBH I'm a bit nervous of messing with the airbag.
My van: 2008 Berlingo 1.6 HDi Enterprise - a bit ratty!
Threads: 11
Thanks Received: 5 in 5 posts
Thanks Given: 83
I've got the same problem, MOT coming up soon!!! but I discovered on mine, if you take the keys out, turn the steering wheel until it locks, give the horn a couple of toots, it will work normally for a while, might be worth a try.
Threads: 67
Thanks Given: 237
50
Usually it is the earth return connection under the airbag that causes the issues - remake the connection with a screw or rivet rather than the push fit connection.
Serieal Berlingo owner
• RattyCortina
