Threads: 123
Thanks Given: 250
34
Yes, there is a seal on both driveshafts where they enter the gearbox.
Thanks Given: 39
13
On drivers side drive shift (uk) there are two long horizontal bolts 8mm diameter I think, with tabs where the intermediate bearing is. You need a deep socket to tighten /check the nuts are tight. The tabs have to be positioned correctly to clamp the bearing. If removing the shaft these have to be slackened right off and bolts rotated 90 ' to allow shaft and bearing assembly to be withdrawn.
