Threads: 30
Thanks Received: 55 in 42 posts
Thanks Given: 104
I've been considering getting a couple of spare wheels and fitting them with winter tyres for use on the front wheels. Looking through the owners handbook today I noticed a warning that this type of tyre is to be fitted you should fit a specific type of wheel bolt which is 'available from your Citroen dealer' - of course! I must admit that I haven't read all the forum threads on these tyres, but have not read of this requirement in the ones I have read. I expect everyone else fits them though....or do they....???
Threads: 101
Thanks Received: 276 in 220 posts
Thanks Given: 384
Steve Valentine uses winter tyres.
Sure he will give you some advise.
(Or PM him...)
Threads: 52
Thanks Given: 87
5
Don't have a Mk 2 here but used the original bolts to mount my four winter tyres that are mounted on a spare set of standard steel rims. Never had a problem.
Threads: 32
Thanks Given: 18
(22-01-2012, 02:05 PM)3rensho Wrote: Don't have a Mk 2 here but used the original bolts to mount my four winter tyres that are mounted on a spare set of standard steel rims. Never had a problem.
Same here.
A little tip to the O/P
Fit winter tyres to
all four corners, because, come the slippy stuff, if you fit them to just the front, you just may see the back of your vehicle trying to overtake you!
Threads: 101
Thanks Given: 384
Knew Steve would come to the rescue with some helpful advice.:thumbsup:
Threads: 16
Thanks Given: 46
5
Winter tyres are not just for getting you out of thick snow they are for use in temps below 7degC including at motorway speeds in the dry. You need to fit 4. If you use the same steel wheels the bolts will be the same.
Threads: 32
Thanks Given: 13
I also have M&S tyres on and used the normal bolts.
I can't for the life of me see why you would need a special bolt??
Threads: 52
Thanks Received: 82 in 67 posts
Thanks Given: 9
I would double check if you are going from alloy wheels to steel wheels, as the bolts might well be different. As said earlier, you need to fit winter tyres to the rear as well.
Threads: 63
Thanks Given: 410
23-01-2012, 05:30 PM
(This post was last modified: 23-01-2012, 05:31 PM by andy-womble.)
