  • 19 Vote(s) - 2.58 Average
Tyre Pressures
I have a Citroen Berlingo Multispace 5 door diesel motor on a 08 plate and I need to pump the tyres up at little but cannot find a pressure guide for psi in the book, it only mentions bar. Please can someone give me some assistance.
Bar is OK and is the modern way of expressing p.s.i.
My MkII 1.6 diesel has on the drivers door frame 2.3 bar (all round) which converts to around 33.5 psi.
Here's a converter to help you do the sums:
http://www.centauro-owners.com/articles/psibar.html
  • tedsui
My door sticker says 2.4 bar empty and 3.2 bar at max load. I generally run at 2.5 bar with both winter and summer tyres.
[-] The following 1 user says Thank You to 3rensho for this post:
  • tedsui
This is a good site.
Input your registration number and results in psi and bar.
http://www.tyre-pressures.com/
Thank you.:thumbsup:
[-] The following 3 users say Thank You to j90xxx for this post:
  • adam3rdcanvey, ron, tedsui
Not sure it's that good.... it says mine has 165 tyres when the standard is 185, hence the pressure can't be that accurate. Says 37 psi. I've never had them that high.
[-] The following 1 user says Thank You to tucker for this post:
  • tedsui
Sad Same here. It says I could have two sizes fitted and both are 14" rims. I have 15" rims and that is correct for the model. ( 185.65.15 )
Today 12:02 PM
Berlingo 2026
Today 03:17 AM
Yesterday 02:32 PM
09-07-2026 12:15 AM
09-07-2026 12:12 AM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
P1A9C
29-06-2026 06:05 PM
28-06-2026 03:35 AM
