  • 7 Vote(s) - 2.43 Average
what are these display?
hi
before i start the car i get these readings on the display.
what does the spanner and 12100 mean?
is it 12100 miles overdue for a service?
also,what is this min--max thing?
i have tried downloading the book but no joy, just ended up installing a download management program that i need to delete now!
2.0 hdi
Attached Files Thumbnail(s)
The numbers are the service indicator.
If its going down its miles to next service (mine is).
You can reset it yourself if you do your own servicing.
The symbol display is the 'electronic' dipstick. Should be on the max.
(Always a good idea to 'dip' your oil aswell.)
The electronic dipstick can vary quite a lot though between starts.
Always a good idea to lift the bonnet and do it the old fashioned way.:thumbsup:
electronic dipstick? so is this giving me a level indication or time to change, is mine showing full then?
i will check to see if the numbers go down over the next couple of weeks,if i do a service myself, how do i reset the spanner mileage?
HI
Correct, your oil is showing full - one square indicates the minimum.
The following post is excellent and provide the sequence to reset the service indicator at the end.
http://www.berlingoforum.co.uk/showthread.php?tid=1955[/align]
The spanner will remain lit when the service is due within <1000 miles
nice link thanks
Last Post: Desdinova
08-09-2026 05:46 PM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
23-08-2026 06:25 AM
