Threads: 38
Thanks Received: 4 in 4 posts
Thanks Given: 21
03-09-2021, 04:08 PM
(This post was last modified: 03-09-2021, 07:43 PM by uk_friendly_fire.)
That's twice so far in 6 weeks I've turned the engine off instead of releasing the electric handbrake, much to my embarrassment and annoyance of following traffic.
Maybe Citroen needs to re-site them.
Anyone else suffer the same embarrassment?
2021 Berlingo Flair M (K9) 130D
I.T. is there to help, but unforgiving if you make a mistake
Threads: 20
Thanks Given: 7
14
i never touch my handbrake - it comes off automatically when you pull away either forward or reverse
Threads: 38
Thanks Given: 21
If you don't manually release the parking brake I can feel the car's rear sit momentarily. This compresses the suspension slightly and must also put force on the braking system before it releases.
I wondered that manual release would be better to reduce wear.
Threads: 67
Thanks Given: 238
50
I was waiting in a queue outside my local tip ( recycling centre for the precious ) and I spotted the car in front doing a merry dance every time it tried to move forward - the back end was dipping and compressing the suspension fully each time ! It was taking probably five or six attempts to get the car to move forward.
Not having the dubious pleasure of an electronic handbrake I couldn't say whether it was driver error or a system fault, either way I'm sure the driver wasn't happy I know I wouldn't be.
Serieal Berlingo owner
Threads: 2
Thanks Received: 56 in 52 posts
Thanks Given: 38
8
(04-09-2021, 11:30 AM)uk_friendly_fire Wrote: I wondered that manual release would be better to reduce wear.
Absolutely not. Wear at zero speed is virtually inexistent.
ex: 2003 1.4i cargo
Threads: 11
Thanks Received: 32 in 32 posts
Thanks Given: 3
7
I am also not a great fan of the electric parking brake. But I am finding it gets better with use. I park in a barn where the floor slopes down, so need to reverse uphill on the way out. To enable me to erect the security post behind I have to park about 150mm from the wall.
At first it was a case of too many revs and clutch slipping to prevent any forward motion, but with use I can now ease up the clutch and just dab the throttle, this allows me to reverse out with no throttle at idle speed, just how I like it, modern diesels have loads of torque, so don't need lots of revs.
I now find I have to remember to apply park brake when driving other vehicles!!!!!!
Geoff
