Rear washer/ wiper randomly turning on
The rear washer / wiper on my 2012 berlingo randomly does a wash/ wipe when I'm driving along. It's done this for a few years but has started getting more frequent.
I'm guessing it must be a problem with the switch on the wiper control stalk? How easy is it to replace this, or alternatively is there a relatively easy way to deactivate the rear wiper and washer control?
(14-09-2021, 11:02 AM)ed34 Wrote:  The rear washer / wiper on my 2012 berlingo randomly does a wash/ wipe when I'm driving along. It's done this for a few years but has started getting more frequent.
Exact same problem with the exact same age of Berlingo. Would also like to know what could be at fault because I’m dumping screenwash left, right and centre.
I want to keep the wiper/wash function though.
This has also recently started (3/4 months) on my 2014 XTR.
It has also become more frequent lately, switching itself on 6 times on this mornings 10 minute drive.
I've no idea where to even start looking to try and resolve this.
In the OP the poster stated it happened randomly while driving along. To me, that would point to something like a chafing wire, rather than a switch problem. The loom to the rear wiper runs through a conduit into the rear door. I would start by removing the rear door panel [use a plastic trim removal tool, or some other such soft item, so as not to damage the panel] and remove the connector from the rear wiper motor and check the loom in the rear door, maybe even pulling the loom back a bit where it enters the car to see if there is damage inside the conduit, as that is the part where the loom is put under most stress when opening and closing the rear door. Normally these systems have a supply at the [in this case] wiper motor and are just looking for an "earth" signal [provided by switch operation] to complete the circuit and run. If you have a wire chafing on a piece of bodywork and shorting the conductors to earth then the circuit is completed and it will operate, so when you drive along going over bumps etc occasionally the wire will contact a piece of bodywork and short to earth.
One other thing, you will probably need to purchase some new trim clips for the rear door panel, as they are plastic and normally break on removal, as the plastic "ages" and goes brittle. These are readily available on Ebay and from other sources.
(25-09-2021, 03:35 PM)Multispacer Wrote:  In the OP the poster stated it happened randomly while driving along. To me, that would point to something like a chafing wire, rather than a switch problem. The loom to the rear wiper runs through a conduit into the rear door. I would start by removing the rear door panel [use a plastic trim removal tool, or some other such soft item, so as not to damage the panel] and remove the connector from the rear wiper motor and check the loom in the rear door, maybe even pulling the loom back a bit where it enters the car to see if there is damage inside the conduit, as that is the part where the loom is put under most stress when opening and closing the rear door. Normally these systems have a supply at the [in this case] wiper motor and are just looking for an "earth" signal [provided by switch operation] to complete the circuit and run. If you have a wire chafing on a piece of bodywork and shorting the conductors to earth then the circuit is completed and it will operate, so when you drive along going over bumps etc occasionally the wire will contact a piece of bodywork and short to earth.
He says it washes and wipes! So not only wiper motor is running, it's like it has the command to wash and wipe, so I don't think that an short circuit or wire chafing will cause this..
If you like gaming visit GameForest
Yeah definitely the wash wipe command, it does the spray and the usual 2 or 3 wipes then stops. It always washes, never just the wiper itself.
(28-09-2021, 08:59 AM)ed34 Wrote:  Yeah definitely the wash wipe command, it does the spray and the usual 2 or 3 wipes then stops. It always washes, never just the wiper itself.
I just posted about an EML warning on a friends 2012 Berlingo - he has exactly this same problem too.
Unfortunately I cannot help you, but I have the same exact situation with a much older Peugeot 307 (2007). The headlights were coming on randomly, so I replaced the whole COM2000 unit, exactly the same unit with wiper stalks, etc. The problem was a faulty headlights switch.
With the replacement COM2000 unit the headlights work without a problem, but the rear wiper turns on randomly (once per drive, sometimes at the beginning but it could be later on) and the wash also turns on, so it washes and wipes. If I switch the rear wiper on at the beginning it does not do anymore. It was  not doing it before, so it is not chafing or broken wires.
I think the BSI is somewhat locked to a COM2000 unit, but I have not investigated why it does it and if it can be fixed.
Did anyone get anywhere with the random rear washer and wiper problem? Took ours to Citroen dealer as they hoped software update would solve. No joy :-(.
Yes, did anyone actually resolve this? I found several threads on google about the issue, but no one reported back with a solution. Did they all scrap the car or make the dealer take it back?
Today 12:29 PM
Yesterday 07:46 PM
Last Post: CB-K9murph
Yesterday 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
Mark 3 camper van conversion
Last Post: minkybeau
23-05-2026 07:38 AM
