tailgate light
There's a rubber filler panel on the inside of my tailgate, pretty much directly behind the high brake light.
Do more exotic models have a light there ? I could mount a generic one (perhaps I should, the default coourtesy lights are pretty dim) but I'm curious whether it fits something standard, like the Relay's interior light (a rounded rectangle).
2016 1.6 BlueHDI Feel MPV / Blaze WAV
Not mine Italian B9.. but there is a sort of "pre-cut line" in the panel that reveal a clue that at least they talked about it in pre-production phase.. Smile
2009 B9 Multispace petrol 1.6 16v 90HP that runs around Italy
I've got this feature in my B9 with a large grommet in it. I always assumed it was for access to the high level stop light. Perhaps I've been wrong?
Matt
   previous
   2016 1.6 HDi 100 XTR Grey Met
   2010 1.6 HDi 105 XTR Gold Met
(17-09-2021, 08:43 PM)Matt Haigh Wrote:  I've got this feature in my B9 with a large grommet in it. I always assumed it was for access to the high level stop light. Perhaps I've been wrong?
I think you're right, actually. I didn't think of that until I pulled it out and realised it was right behind the brake light.
I've ordered a square led panel to put over it and make a nice loading bay light when the door's up.
https://www.ebay.co.uk/itm/133817452945
I've also been experimenting with W5W LEDs for the existing interior lights as I find the factory bulbs gloomy.
Initially I bought some 6000K 35 lumen bulbs from Halfrauds. https://www.halfords.com/motoring/bulbs/...24090.html Actually not bad at £3.50 for two. They're not a great help with the overall lighting but I've put them in the individual front courtesy lights where they whiten the illumination nicely while not being too bright for driving.
Then I got some much brighter, but still 6000K bulbs. 180 lumen :  https://www.ebay.co.uk/itm/184871138840. These were disappointing. Fairly bright, but with a strong purple tint. On examination , they seem to have a similar spectrum to the Halfords bulbs but with an additional peak in the violet area. They're quite odd - they have normal SMD LEDs on the pcb (not COB) but the resin coating has yellow in it - presumably the fluorescent stuff used to make the white. There isn't a sold slab of yellow phosphor material like you usually see in white LEDs. I think that the phosphor is mixed with the epoxy to make a glowing blob, but it's not thick enough so a lot of the underlying blue/purple leaks through. They're also physically a lot longer than a W5W and only just fitted under the berlingo's lens.
So I got some different ones. Again, 6000K, but 240 lumen. https://www.ebay.co.uk/itm/184436698880 . I'm pleased with these. Nice bright white like the Halfords one but way brighter. And the control circuit is a little switch-mode regulator inside the head, instead of just resistors. The whole car lights up now when I blip the key instead of just having two gloomy pools. I will try the same manufacturer for others I want to replace like the reversing lamps.
They cope with the automatic dimming OK - fine at normal levels but flicker a little just as they're going out. I may fix that if it annoys me.
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
