Replace basic/standard radiodisplay
Has anybody replaced stock/standard radioterminal to original upgrade multi display. Is that change possible to make if i get my hands on used unit?
(18-09-2021, 11:26 AM)Nikllas Wrote:  Has anybody replaced stock/standard radioterminal to original upgrade multi display. Is that change possible to make if i get my hands on used unit?
Do you mean to replace your original basic unit with one that has sat nav?
No difference. You will need both the display and main telematic unit and have them be coded to the car.
Unless you want to go original there are Android units available in Aliexpress
ex: 2003 1.4i cargo
(19-09-2021, 09:34 AM)boop Wrote:  No difference. You will need both the display and main telematic unit and have them be coded to the car.
Thanks you both! For the information.
I would go for the Android after market option, the standard unit is a bit laggy and can self destruct when updating if your not careful.
The 2021 Nov onwards Berlingo / Rifter / Combo Life has an upgraded unit if you go for the higher trim which is much better to use.
Last Post: Desdinova
08-09-2026 05:46 PM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
23-08-2026 06:25 AM
