19-09-2021, 12:15 PM
Can anyone help with the following, please?
I have an oil leak which I assume is from the gearbox. On the attached photograph it can be seen on the aluminium(?) casting against the light area in the background (it's a caravan). It seems to be coming from near the gearbox drain plug and running to form the drip. I don't think it's from the drain plug as there is no sign of it and there is a gap between the plug and the casting.
If I clean it up it does not reappear overnight. However, when I take the car for a short run it's there again immediately. I've tried to find diagrams etc to tell me what the casting is without success. It appears to be attached to the gearbox with fixings through two hexagonal "tubes". I've tried nipping these up but it made no difference. Any advice gratefully received !!
