Low beam not working
When driving home from work today, I noticed that the low beams (head lights) didn't work. The high beams however seems to work fine, so I don't think the bulbs are at fault. I've also checked the fuse to the head beams, that seems to be ok.
Any ideas? Could the headlight switch be to blame?
99' Berlingo Multispace
265.000 km
Could it be the relay ?
The rear lights are working?
Yes, rear light are working fine. How can I check the relays?
265.000 km
Is there a fuse for the low beams?
(21-09-2021, 06:59 AM)cancunia Wrote:  Is there a fuse for the low beams?
Haynes shows separate fuses for N/S and O/S , for dipped and main beam (4 x 10amp), presumably for safety so that the lights (unlike the UK) won't all go out at once!  As both lights go out on dipped it could point to the relay or switch?
(21-09-2021, 11:01 AM)oilyrag Wrote:  Haynes shows separate fuses for N/S and O/S , for dipped and main beam (4 x 10amp), presumably for safety so that the lights (unlike the UK) won't all go out at once!  As both lights go out on dipped it could point to the relay or switch?
I took a guess at the model number, so the attached diagram may be wrong but worth checking.
Looks like there are 2 fuses for the dipped & 2 for the main as noted above, so if the bulbs & fuses are ok, the common point is the lights switch itself.
.pdf   M49 Lights.pdf (Size: 642.35 KB / Downloads: 9)
^^^^ not the best diagnostic method I have to say !!
My advice would be to check the bulbs with a meter before doing anything else and if you don't have a meter then buy two new bulbs.
Thank's for all the good answers!
I changed the bulbs, and that seemed to fix it. I guess the low beam filament must have burnt out, while the high beam still functioned?
Anyways, it's always good when there is a easy solution Smile
265.000 km
1.6hdi starting problem
14-10-2026 01:38 PM
12-10-2026 02:50 PM
12-10-2026 02:31 PM
12-10-2026 11:22 AM
» Replies: 76
06-10-2026 12:46 PM
06-10-2026 10:00 AM
