Pollen filter
Hello I have a new berlingo 2019 1500 130 hp does anyone know how to change pollen filter is it the same as the second generation thanks paul
Hi Paul
I posted this a while ago:
Simply removed the plastic panel beneath steering wheel.
With the aid of a torch I identified the cabin filter cover plate, which although a bit remote was easily removed. It is above and to the left of the clutch pedal.
I then used a very sharp pointed tool to hook first the top and then the bottom filter out.
I would say it took about 2 minutes.
Geoff
[-] The following 1 user says Thank You to Guanock for this post:
  • boop
Yesterday 05:21 PM
Yesterday 05:12 PM
04-11-2026 11:37 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
