[Steering & Suspension] can anyone HELP ! Please
i have a 2.0 hdi diesel 2004 anyway i just put a new driveshaft and NEW gearbox outter seal on the drivers side or right side and i still keep getting a clonking
sound when turning hard left or right any information would be most greatfull
If you jack up each front side in turn do you get the noise when turning the road wheel by hand , or in gear with the engine running on full lock?
Could be something as simple as the anti-roll bar link which attaches to the strut - they wear rapidly and are cheap to replace - I went thro' the same change of drive shaft and only when I changed the links did the noise go away. The hard turning could coincide with a small degree of body roll and the links coming into play. If you disconnect one and the ball joint movement is easy - it's worn out!
Perhaps you have noisy top strut bearings.
Yep, all of the above are possible. If you start with turning the wheels while off the ground, you should get a better idea if it's driveshaft related.
a BIG THANK YOU to all the commments i will be looking into all the above comments and see what is going on
  Smile
(25-09-2021, 03:05 PM)cancunia Wrote:  If you jack up each front side in turn do you get the noise when turning the road wheel by hand , or in gear with the engine running on full lock?
happens when at a stand still turnning hard left or hard right where i live there is a turnning point if you can call it that people all ways parking there so hence
the hard left or right when turning when you move left or right thats when you here it when moving slowly 100% drivers side wheel area
If the noise is there when turning the steering but stationary, it could be the top strut bearings as GEOFF suggested.
Its the road spring trying to move but the siezed/worn out top strut bearings not allowing the road spring to move freely, twisting it ,then its jumping free with a thump.
OR front sub frame mounting bolts slightly loose.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Whilst exploring all the above it would be worth taking a look at the strut springs as one of them may be broken, quick and easy check just needs a torch and an eyeball.
As above, if it happens when stationary, it's unlikely to be the driveshaft and more likely to be the strut top bearing or perhaps a spring.
Today 08:32 AM
Today 08:16 AM
03-03-2026 06:17 PM
03-03-2026 05:08 PM
03-03-2026 07:57 AM
02-03-2026 02:51 PM
02-03-2026 02:14 PM
Amdro boot jump for sale
Last Post: YTC1
28-02-2026 09:48 PM
Last Post: Muppets on Mars
27-02-2026 01:57 PM
26-02-2026 07:20 PM
