Threads: 40
Thanks Received: 79 in 72 posts
Thanks Given: 129
9
Can anyone recommend an adhesive that will work on outside bits of plastic trim? My wing mirror got bashed a couple of years ago so that the two halves of plastic separated. I haven't wanted to get a replacement if it's fixable (the plastic isn't broken - it just no longer holds together). I patched it up with gorilla tape, which has held it quite well, though looks a bit bodged. Are there any adhesives that will work outside and stick to plastic, and do a neater job than the tape?
Threads: 5
Thanks Given: 4
21
If you ease out the mirror glass from its mount you may be able to access the 'back' of the repair and be able to use hot melt glue etc. or even glass fibre mat & gel, if you have any. I don't like Superglue much but is that a possibility?
The following 1 user says Thank You to oilyrag for this post:1 user says Thank You to oilyrag for this post
• notsofast
Threads: 40
Thanks Given: 129
9
I've never used a hot glue gun, but will look into that, thanks. If buying glue and a gun is dearer than a new wing mirror, I'm guessing that it's a bit of kit that I could find a use for elsewhere too...?
Threads: 11
Thanks Received: 31 in 31 posts
Thanks Given: 3
7
I use UHU Por for all plastic repairs. It sticks foam and plastic.
Geoff
The following 1 user says Thank You to Guanock for this post:1 user says Thank You to Guanock for this post
• notsofast
Threads: 40
Thanks Given: 129
9
Ah, that UHU Por looks promising. According to UHU's web page -
https://www.uhu.com/en/product-page.37252 - it sticks various plastics and is also waterproof. Thanks.
Threads: 29
Thanks Received: 375 in 329 posts
Thanks Given: 67
20
(28-09-2021, 06:56 PM)Guanock Wrote: I use UHU Por for all plastic repairs. It sticks foam and plastic.
Geoff
I remember this from years ago "Im Falle eines Falles klebt UHU wirklich alles".
In case of an accident UHU sticks virtually anything
Threads: 3
Thanks Received: 6 in 5 posts
Thanks Given: 5
U-pol tiger seal was the adhesive of choice for the 90's boy racer body kits ? works a treat and use it quite alot as a builder too super strong and super flexible ?
1999 Mk1 3 door berlingo multispace 1.9d DW8
