Threads: 25
30-09-2021, 04:21 PM
my heater only works on setting 4 full speed, all others by turning the control dial nothing happens, so assume this is something to do with the heater resistor pack or something becoming faulty?
anyone know and its location or any diagrams etc help would be much appreciated, also is the part easily changed and from a main dealer only or any car parts place do them?
many thanks to all?
van is berlingo enterprise 2007 1.6hdi version.
Threads: 29
Thanks Given: 67
20
They are available
aftermarket for £10 to £15 so not too expensive. Don't know where they are on the M59 and I really ought to find out so hopefully someone will help out. Plenty of info on the B9 saying it is up above the accelerator pedal and I looked in the Haynes for M59 but can't see it in there.
Thanks Given: 188
23
The M59 RHD is usually look up the back of the centre console from the passenger side and you will see the wires leading to the block connector in the fan motor if I remember right. Its a bit fiddly and the younger/flexible you are the better.
Are we there yet?????
• ffrenchie
