Threads: 4
Hello guys, the name’s Alan. I’ve just got hold of a Berlingo van and I think I need to confirm exactly which van I’ve got, cos I keep ordering wrong bits for it!
It’s a 2007 van with a 1.4 petrol engine and no air con. The chassis number is (I think) 11161FV10219EWPA.
It’s just run in…well, 220,000 miles…
Threads: 43
Thanks Received: 411 in 368 posts
Thanks Given: 137
32
It will be a M59 model going by the year
more info at
http://www.catcar.info/citroen/
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Threads: 4
Well that should help with ordering parts, thankyou. I was thinking thinking of ordering a driveshaft but there appears to be about ten different lengths available.
Threads: 48
Thanks Received: 272 in 229 posts
Thanks Given: 4
20
The only way to find the right length of driveshaft is to take the old one out and measure it...
And try to guess which one in the online store is the same length only measured differently...
Never did find one that matched the mumbers of my righthand driveshaft... but it seems to fit, so...
(M49, also with a 1.4i )
Threads: 4
Well, I’ve ordered up the driveshafts and will hope for the best. As it happens I think I’ve just got a worn CV joint, so if it’s the wrong length I’ll just change the joint.
