Touchscreen issues!
Hi all,
My 9yr old daughter has managed to smash the glass (just the glass) of the touchscreen display in my 69 plate Berlingo Van!
I’ve been quoted over £600 for a new unit and labour to fit it, they won’t even entertain the idea of just replacing the glass.
Does anyone have expertise/experience in changing the whole unit (much cheaper used units available), or does anyone know where I can get just the glass replaced?
Many Thanks ?
Sometimes there are new or slightly used OEM units available in Aliexpress for a very reasonable price.
ex: 2003 1.4i cargo
Replacement glass would presumably have to enable the touchscreen functionality, and I'm guessing is likely to be rather hi-tech.
Same glass as used on mobile phones, iPads, etc., i.e. expensive. I very much doubt that the glass is available as a spare so trying to source a one-off replacement would probably be more expensive than what has been quoted for the complete unit..
if the display is not broken, and the touch is working as normal then the glass can be changed, ask someone that replaces glass on mobile phones, they will delaminate the broken glass, put a new one and re-laminate.
If you like gaming visit GameForest
[-] The following 1 user says Thank You to deejay_xb for this post:
  • Matt Haigh
£245 unit on ebay but as i thought on the listing it says this will have to be codded to car when fitted
but you might be able to buy the unit and get somebody to swap the glass but be careful screen is ok as we had a laptop glass go and all looked ok changed glass then it started to bleed
DPF & EGR problem error P242F P1490 P11B2 P14A4
Last Post: legepe
Yesterday 07:30 PM
Lost Power 2.0hdi
Yesterday 07:29 PM
TUNING-DIESELS Synergy 1 box (siemans)
Last Post: runningman
Yesterday 04:43 PM
Haynes Berlingo manual 96-2005
Yesterday 04:37 PM
[SOLVED] Engine cover clips
Last Post: benoliver999
Yesterday 03:09 PM
swivel seats hit the brake lever
Last Post: Keith993
Yesterday 12:21 PM
Citroen Lifestyle Berlingo La Parissienne
Last Post: Keith993
Yesterday 12:14 PM
berlingo 1.4i Van gearbox swaps
Last Post: Gadgetman
Yesterday 11:58 AM
Centre Dash Display
Last Post: saskak
Yesterday 11:02 AM
P16A7 fault
Last Post: martinmiller1973@gmail.com
Yesterday 10:28 AM
