Threads: 9
Thanks Given: 2
Hi, got the tyre pressure low front left on the dash and on the clocks...
Thing is I don't have the sensors on the wheels just normal valves and tyres...
Can I turn this feature off anywhere?
Thanks.
2014 B9 1.6 HDI Multispace.
Threads: 5
Thanks Given: 4
21
You could try pumping it up and see what happens!
Threads: 5
Thanks Received: 50 in 38 posts
Thanks Given: 19
6
19-10-2021, 10:39 AM
(This post was last modified: 19-10-2021, 10:46 AM by Buki.)
If there are no sensors in the valves,there is an indirect TPMS system that detects pressure drop by wheel rotation speed, using ABS sensors.
After inflating to the correcr pressure you need to initialize the system via the menu, otherwise the alert will remain.
The following 2 users say Thank You to Buki for this post:2 users say Thank You to Buki for this post
• cancunia, saskak
Threads: 9
Thanks Given: 2
I checked the pressures today.. all tyres at 30psi
Gave them all a blast to 32 and the warnings gone off....
black magic?
Threads: 5
Thanks Given: 4
21
Happens on my wife's car when the air temp goes down -
Threads: 16
Thanks Given: 46
5
27-10-2021, 06:47 AM
(This post was last modified: 27-10-2021, 08:44 AM by Opensauce.)
Your tyre pressures are too low. The pressures are indicated on a sticker on drivers door frame. On mine 2017 Feel they are 2.4bar all round lightly laden & 3.2bar fully laden. In psi this is 35psi all round lightly laden & 46.5psi fully laden.
After adjusting pressures you must do the reinitialisation procedure. On right of radio press menu, OK, Define vehicle parameters, OK, Driving assistance, OK, Tyre pressures, OK, Yes.
