20-10-2021, 01:16 PM
Hi.
I have a 2003 Berlingo Multispace and basically both front door handles (external) seam to have lost their springs (well, probebly more broken) as the handles don't spring back so often when you get in, you need to make such the handle is pushed in before the door will shut. Minor annoyance but still..
Looking online, it seams it's best to just replace the whole handle.. i Think i've found a set for a good price but the problem is removing the old ones.. it appears to be connected by two points.. the bottom is a nut and bolt so should be able to take it off, but the top one appears to be a rivet or something which is an odd choice for such a thing.
best i can find outline says i'll need to drill that out which is very annoying.. but then leaves the problem of replacement (which i guess.. i'll try a nut and bolt that seams to fit). is there any other way then drilling it out for removing that top connection?
