Hello
Threads: 2
Thanks Given: 1
HI
I am new to the forum I'm having so many problems with My Citreon Berlingo I thought I would join a group that could maybe help me out.
Threads: 123
Thanks Given: 250
34
Welcome, ask away. There are sections for each main flavour.
Threads: 2
Thanks Given: 1
20-10-2021, 05:33 PM
(This post was last modified: 20-10-2021, 05:44 PM by TRobbo.
Edit Reason: Spellings
(20-10-2021, 05:15 PM)cancunia Wrote: Hi
I have two error codes P0299 & P242F
P0299 Charge Pressure Regulation: Air Pressure Below The Reference Value
P0242F: Particle Filter: Detected Clogged
As for P0299 I am looking for leaks in the air Intake System and as for the P)242F I be;eive that the DPF needs a clean ?
Also I have read many times that the EGR valve could be an issue. I have seen many videos of mechanics taking the EGR valve out of the engine for cleaning, theses are on the right hand side of the engine underneath the Fuel Filter. I believe that my EGR valve is on the left side of the engine behind the fuel filter.
My Vehicle is a Citroen Berlingo 1.6HDi Variant 7B9HN
any help would be appreciated.
Thank You
Threads: 123
Thanks Given: 250
34
You will probably get more replies if you post in the section of the forum for your Berlingo (M59, B9 etc). Choose a subject that matches the problem as not everyone reads the 'hello' posts.
Threads: 61
Thanks Given: 234
29
I rarely read the hello posts and as cancunia said better post in the relevant section, say M59, B9, etc., a lot better chance to be read and to get replies. Have a good title for the problem and some info on the engine (model, year, mileage, etc.).
Threads: 2
Thanks Given: 1
(21-10-2021, 12:14 PM)saskak Wrote: I rarely read the hello posts and as cancunia said better post in the relevant section, say M59, B9, etc., a lot better chance to be read and to get replies. Have a good title for the problem and some info on the engine (model, year, mileage, etc.).
Thank you for your reply, I think I've now posted in the correct section.
Threads: 5
Thanks Received: 4 in 4 posts
Thanks Given: 2
(20-10-2021, 05:15 PM)cancunia Wrote: Welcome, ask away. There are sections for each main flavour. Welcome, im a new user as well
Citroen Berlingo M 1.2 Puretech XTR Flair Auto, EAT8, Cumulus Grey
with:
Drivers Assistant pack (Hmm was Not Installed but we did pay for it  )
Keyless Entry
Threads: 5
Thanks Given: 4
21
Looks a rum'un - I thought that Escorts were Fords, not Citroen!!
