blower motor not working right
i have a 2009 berlingo the heater blower only works on settings 1 3 and 4 not a big deal i know but id like to fix it any advice would be great ?
It could be the heater resistor pack has failed but they usually fail on the first 3 speeds and work on number four. But the resister could have failed on speed 2. They are usually easy to replace up under the dash with possibly a bolt and then clipped in with a plug socket to disconnect.
You dont say which model you have as your year is a change over year between the M59 model and the B9 model.
(22-10-2021, 01:24 PM)Tomcat3 Wrote:  It could be the heater resistor pack has failed but they usually fail on the first 3 speeds and work on number four. But the resister could have failed on speed 2. They are usually easy to replace up under the dash with possibly a bolt and then clipped in with a plug socket to disconnect.
its the 1.6hdi multispace 2009.thanks for your reply
Last Post: BDRichardson
Today 04:07 PM
Yesterday 09:56 PM
04-09-2026 05:28 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
23-08-2026 06:25 AM
