22-10-2021, 07:32 PM
I'm having some issues with my 2003 Multispace 1.9d. When setting off, the central display peeps and shows driver door open when it is firmly shut. This also seems to stop the central locking working - it momentarily locks then unlocks. If I manually press down the driver door locking button, using the key fob or the key in drivers lock will centrally lock all the other doors, and they will all unlock with key in drivers lock. I am assuming there is some sensor in the drivers door that is not working when the door is closed. Does anyone know where this is and if it is fixable?
Second problem is the adjustable headlight aim. When headlights were on, the adjusting motors were constantly wirring, but the aim did not alter when moving the position switch. I have tried manually moving the bulb holder and reflector and the wirring has stopped and sometimes the aim will now adjust with the position switch - but not always working. I may just have to leave the position switch alone and hope the constant wirring motor struggling doesn't re-occur. Is the headlight a sealed unit with adjusting motor or is there a way to get into it to free it up or clean contacts? There is a white plastic bolt on a plastic motor extrusion - does this have anything to do with adjustments?
Third problem is the airbag warning light is staying on. I have tried cleaning the electrical connector under the drivers seat which at first cured it, but it is now back on and cleaning the connector has no effect. Is there anything else to try to sort this out?
Thanks for any helpful advise.....
