25-10-2021, 12:39 PM
(This post was last modified: 25-10-2021, 12:40 PM by mistabig.)
Hi,
I removed my dash to do a few things to the car. After reinstalling everything i have 9 codes.
p0351 Ignition coil a primary control circuit/open
p0352 Ignition coil b primary control circuit/open
p0420 catalyst system efficiency below threshold bank 1
p0201 cylinder 1 injector A circuit
p0203 cylinder 3 injector A circuit
p0204 cylinder 4 injector A circuit
p0202 cylinder 2 injector A circuit
U0028 vehicle communication bus A
P0444 EVAP system purge control valve A Circuit open
The car cranks but doesn't not start.
It is a 2005 model
Anyone have any idea what could be unplugged or damaged?
Could this be a grounding issue?
Could a bad bsi cause this?
I checked the 3 grounds by the gear selector and the bsi appears to be all plugged in correctly. The indicator lights and the headlights do not work when moving or turning the stalk. The headlights turn on when i turn on the ignition even with them set to off.
I have tried a bsi reset 4 times and nothing changed each time.
I did wash the interior as the passenger floor was flooded and mouldy prior to me buying the car. I may have gotten the bsi a little wet.
What would be the procedure to correctly diagnose the bsi and what would be the cheapest option to replace/repair it?
Threads: 43
Thanks Received: 415 in 372 posts
Thanks Given: 137
33
Looks like you have water in the BSI. See if a spell in a warm place will help to dry it out.
There is/was a firm that repairs them " BBA reman" If still existing you could try them if warmth doesn't work. There are a few posts about repairing them on here.
https://www.berlingoforum.com/thread-209...BSI+repair
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Threads: 43
Thanks Given: 137
33
How did you get the DTCs in your first post? Do you diagbox/lexia ?. Its the Citroen/Peugeot diagnostic system. It will give you the DTCs on your motor. More dependable than a general OBD11 reader.
If not search this forum for Diagbox, lots of posts.
You will find a lot of plugs in the wiring loom, they are there for different specifications for your model which you may not have, as you say.
Are all your earths reconnected Are all the plugs reconnected as it looks as if there is a common fault with your injector circuit , ie not connected to the ECM.
