Interior lights
My van's rear interior light seems to have developed a weird fault. I recently noticed it was on when I was reversing onto the drive, I first thought it was coming on with the reversing lights. Had a play about this afternoon and discovered that with the switch in the 'off' position it comes on with the ignition, in the 'door' position it seems to behave normally. Also the front one will only work when switched on manually if the key is in the first position. (although that may be normal?)
My van: 2008 Berlingo 1.6 HDi Enterprise - a bit ratty!
Berlingo digital cluster speedometer upgrade
Last Post: kaktusas
Yesterday 02:48 PM
Cruise control retrofit
14-12-2025 09:37 PM
14-12-2025 01:33 PM
14-12-2025 12:49 PM
14-12-2025 12:00 PM
Anti Pollution fault warning
14-12-2025 11:39 AM
An almost Hydrolock in a DV6B
Last Post: chrisl
14-12-2025 09:36 AM
Last Post: chrisl
14-12-2025 09:27 AM
tyre pressure monitoring system (TPMS)
10-12-2025 07:50 AM
Wishbone Lower Control Arms Questions
09-12-2025 07:19 PM
