Threads: 7
Thanks Given: 2
Hello All,
Got the subject warning and battery icon on the dash out of the blue last night. Stopped car and restarted several times, warning seems to come on 3 minutes after restarting and stays on until engine turned off. Everything seems to work, but the wipers seemed slow right before the problem started, and still do. They don't seem to be straining, or making any strange noise. I'm hoping that might be a lead to what's wrong. The fault occurs with or without wipers being on. I think it's OK to drive, but it is a long way to a Citroen dealer.
Any one have experience with this?
Thanks!
Threads: 5
Thanks Given: 4
21
Might be worth some basic checks - is the alternator belt good/tight and the battery connections firmly in place. If you have a test meter then look for 12.6 volts resting, 13.6/14.6 when running, at the battery terminals.
Threads: 7
Thanks Given: 2
Thanks - I don't have a meter, but your reply and other research point to a bad alternator or connections as easy places to start.
Thanks Again
Threads: 5
Thanks Given: 4
21
Even without a meter try switching the headlights & heater fan/wipers on at tickover to load the battery and then increase the revs - the lights should get brighter as the revs increase if the alternator is doing its job.
You may even have a cell in the battery beginning to fail, so get it checked before buying a new alternator.
The following 1 user says Thank You to oilyrag for this post:1 user says Thank You to oilyrag for this post
• Davo
Threads: 7
Thanks Given: 2
Thanks - Now that I was able to see well in the daylight, the drive belt was broken in half and just dangling under the car. It's probably the newish big stop/start battery that's keeping things running. I'm hoping it was just its time to go and not one of the pulleys out of alignment; it looks unevenly worn.
Threads: 5
Thanks Given: 4
21
Not much can go out of alignment, but if the belt slips/stalls it ends up with worn patches that exacerbate the wear pattern. I'd guess that a new belt, correctly tensioned, will do the job.
Threads: 40
Thanks Received: 79 in 72 posts
Thanks Given: 129
9
Could one of the pulleys have seized?
Threads: 7
Thanks Given: 2
All good after replacement. On the plus side, the stop/start started working after a year of not. Don't know if reseating the sensor did it, or if the electrical system wasn't getting the charge it wanted from the drive belt for some time.
