9" multimedia player for the B9
Threads: 73
Thanks Received: 44 in 33 posts
02-11-2021, 06:51 PM
(This post was last modified: 02-11-2021, 07:03 PM by Tikki.)
9" Multimedia player in the B9 is no problem any more. And you wil have all the luxury of a tablet.
With android apps. Reversing camera. And mutch more.
Mine is a teyes cc2
Just plug and play
The only thing is first time setup of the radio and get to know the menu system, since the basic language is in russian.
after switching to your native language its no problem any more.
The stalk controll works as normal.
The menu settings is not directly adapted for the berlingo. But i found out that the settings for peugeot 308 is compatible. and if you have the electronic AC that can be controlled from the player.(this not a problem,and has no effect on the every day use on a low tech berlingo)
Even the reverse lines adjust as you turn the steering wheel if you have a camera.
Threads: 46
Thanks Received: 155 in 125 posts
Thanks Given: 34
21
(02-11-2021, 06:51 PM)Tikki Wrote: 9" Multimedia player in the B9 is no problem any more. And you wil have all the luxury of a tablet.
Mine is a teyes cc2
Just plug and play
Even the reverse lines adjust as you turn the steering wheel if you have a camera. Thanks for this, can you still actually adjust the time/other setting on the existing multi-function display, that I can see in you vehicle?
Thanks Received: 5 in 5 posts
Thanks Given: 8
With the head unit off press and hold the Vol - and Vol + together. The dash will enter into the menu that you'd normally have pressed the Menu button on the Blaupunkt unit to get to.
Search up and down change the menu item, VOL+ is yes, Vol - No, scroll wheel will swap between hours and mins + the date etc
Threads: 73
its no problem to adjust the clock and settings of the dash display. There is a menu in the multimedia player sub car menu where you can adjust all the settings. Time,date,temperature, and even se the simple diagnostic.
if you buy the obd2 dongle for the player you can se live data and error codes in the obd2 app.
Threads: 46
Thanks Given: 34
21
(03-11-2021, 06:19 PM)Tikki Wrote: its no problem to adjust the clock and settings of the dash display. There is a menu in the multimedia player sub car menu where you can adjust all the settings. Time,date,temperature, and even see the simple diagnostic.
if you buy the obd2 dongle for the player you can see live data and error codes in the obd2 app.
Thanks for all the information. Can I ask, how long did it take for the unit to arrive [from China?]
Threads: 73
It came quite fast. 2 weeks from china to norway.
The following 1 user says Thank You to Tikki for this post:1 user says Thank You to Tikki for this post
• Multispacer
Threads: 0
08-01-2022, 07:44 PM
(This post was last modified: 08-01-2022, 09:29 PM by Frazo.
Edit Reason: Found answer
(05-11-2021, 06:00 PM)Tikki Wrote: It came quite fast. 2 weeks from china to norway.
Looks good man , I'm on there website and the options don't seem to include a fascia unit , just the interior pry tools , do you have a link for yours ? Or did you buy parts separately ? Thanks
Threads: 73
10-01-2022, 10:02 PM
(This post was last modified: 10-01-2022, 10:03 PM by Tikki.)
(08-01-2022, 07:44 PM)Frazo Wrote: (05-11-2021, 06:00 PM)Tikki Wrote: It came quite fast. 2 weeks from china to norway.
I got the CC2P version Link
here is the cc3 version Link
Inclueds: Facia. Wire harness. Gps and 4g antenna. 3usb. Some rca connectors.
I would Recomend to buy a mic, and the sold separately rca connectors. If you have a sound system with rca connectors.
The installation is Super easy.
Remove glove box to get better acsess to route the antenna wires.
the rest is plug and play
A link to the Teyes Manual you get with the system
cc2p.teyes.ru
cc3.teyes.ru
• Matt Haigh
Just wondering if you are still pleased with this radio? Did anyone else buy one too?
Threads: 43
Thanks Received: 410 in 367 posts
Thanks Given: 137
31
I fitted a Teyes cc3; very poor in fact no real instructions on how to fit it and what Menus/buttons /etc do. No paper manual. Careful what you order because if you buy the twin usb dash lead you can't fit DAB adaptor because that port is occupied.
It gets very hot and you are not told it can be converted to a single din with a special bracket that costs a overpriced £30. Only found out after cutting out the space for a double din unit.
Postage is another high expense. Shipping is 72 dollars.
Sim cards are problematic some work some don't that is if you want to try to use the phone set up. The teyes phone app supplied with the unit just will not work for me , had to download the phone app from goggle to try to use, gave up on that. It may have been me not pressing or being able to find some button somewhere but with no paper manual it is quite difficult to figure out.
There is no provision for it working on the accessory position. Its either on with full ignition or not on at all. The on/off button does not work unless ignition is fully on and I cant find a way to wire it up without losing the magic box called canbox which allows the original clock screen to work.
The radio is OK but a bit primitive, it is only frequencies and no station names. DAB gives the station names etc but FM doesn't If you lose a signal it just sits and does not seek another station. No automatic tuning. There is a small AFT button but it does not seem to do anything. There is supposed to be a software upgrade which is supposed to cure this but I couldnt get it to upgrade.
You can use the teyes radio app but no local /regional/BBC stations on the list. If you figure out a list of radio stations and frequencies and tell them they will update their system and you can then download the radio station names. Why do all that when it could have been done at the factory in china where they are made.
Wondered why payment/prices are in Australian dollars. and the videos built in are either Russian or Chinese.
The supplied mounting is very poor , the unit jumped out of the dash 2/4 times when hitting a pothole. Had to adjust it before it would stay in.
The screen is very reflective on a sunny day so much I cant see what's on screen , If it was adjustable about 20/30 degrees upwards it would help the readability of the screen. The very small text doesn't help. The screen protector may be a large cause of it but it is needed because of the hundreds of times I had to take it out and in to correct the wiring. There are masses of wires that come with it.
The OBD11 is too long to fit in the space behind the B9 glove box lid. so the plug is just hanging . I asked about this and was advised to use an adaptor which was even larger.
With hindsight I would look elsewhere for an android head unit.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Berlingo undertray
Today 07:56 AM
» Replies: 16
Today 07:07 AM
Yesterday 08:32 AM
Yesterday 08:16 AM
03-03-2026 06:17 PM
03-03-2026 05:08 PM
03-03-2026 07:57 AM
02-03-2026 02:51 PM
02-03-2026 02:14 PM
Amdro boot jump for sale
Last Post: YTC1
28-02-2026 09:48 PM
