Threads: 3
Thanks Given: 3
02-11-2021, 09:53 PM
(This post was last modified: 02-11-2021, 09:55 PM by Mark1.)
I thought smoking in cars was banned but apparently not. Just changed the alternator and the belt did'nt want
to go on. When I finally got it on and released the tensioner I thought it was a bit tight (like its owner)
Belt began to smoke after about 30 secs. Belt over hanging on the tensioner, tipping the belt to rub on the returning belt
run. Moved it back over but the same thing happened again. Am I going mad, the belt can only go on one way surely!
Thing is the car has been standing a few months and belt left slack, could it have shrunk and maybe being coldish didn't help!
It's an m59 dw8 (wjy) 1.9 if that helps
Threads: 123
Thanks Given: 250
34
Is the new alternator aligned properly?
Threads: 3
Thanks Given: 3
Think the tensioner pulley is borked. Put a new auxhiliary belt on (a 6pk 1437)
which was the same length as the old on and the same thing happened, it began
to slip off. Could see the t/pulley has lost its spring pressure and moves back
too easily when belt is on.
I believe this belt is too small, it was an absolute pig to get on. I think i need
a 6pk 1447 I will speak to the local motor factor tomorrow
Threads: 3
Thanks Given: 3
Guy at lmf was certain he supplied the correct belt, said he'd never
heard of a 1447 for my model.
I know it's had a different sort of alternatorfitted at one time think it
was off an 02 1.4 pug 302 or summat but has been working fine unti
recently.
Threads: 43
Thanks Received: 412 in 369 posts
Thanks Given: 137
33
It may just be the angle of the photo taken but it looks to me as if the belt is running too close to the alternator body. Is the alternator the correct one and is it mounted on the mounting bracket correctly?
It looks to me as if it needs to move to the right a little.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
