horn
Can anyone help please my horn only works when the engine is switched off when engine is running it dont work can anyone help with this mystery
I had such a problem, fixed by cleaning the horn contacts behind the airbag and lightly tightening the ground wire to its place.
(04-11-2021, 05:02 PM)Buki Wrote:  I had such a problem, fixed by cleaning the horn contacts behind the airbag and lightly tightening the ground wire to its place.
I will look into this thank you
Hi daz13, did you manage to get this fixed?
I am experiencing the exact same issue on my 09 berlingo first.
LOADS and loads on horns on site, have a search ... plenty of answers too.
The original earthing route through the steering column bearings has 'dried up' / increased in resistance.
I bodged it for the MOT by stripping the insulation off a long section of single strand cable, wrapped it loosely round the lowing steering column in the footpedal area and then attached on end to the bulkhead.
I neated it by installing a long woven 'earth braid's as fitted to industrial electrical cabinets. This lightly rubs the steering column without restricting the column turning and provides a good earth.
2004 Peugeot Escapade 2.0HDI. 115k miles
2004 Volvo V70 2.4  208k miles
2011 Volvo XC90 215k miles
2005 Porsche Cayenne 170k miles
[-] The following 2 users say Thank You to Kyleonsite for this post:
  • RattyCortina, RJBingham
(03-03-2022, 07:10 AM)Kyleonsite Wrote:  The original earthing route through the steering column bearings has 'dried up' / increased in resistance.
I finally got round to looking at mine. I also used an earth braid, attached one end to the convenient stud near the bottom of the column, wrapped it round the column and used a short spring to put a little tension on it. A bit Heath Robinson but at least the horn works (for now!)
[Image: img_2186.jpg]
My van: 2008 Berlingo 1.6 HDi Enterprise - a bit ratty!
Yesterday 05:30 PM
04-11-2026 11:37 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
20-10-2026 06:45 PM
» Replies: 45
18-10-2026 06:46 AM
» Replies: 82
