Hey guys...new to the forum but looking to see if anyone has had the same problem as me and if they found a solution.
I have a 2016 Berlingo Feel Blue and my story starts with a dead battery! I bought a new one and a few weeks later its drained so I get a new alternator fitted! Now my car lasts a couple of weeks at most then the battery is down to 11 volts or under and ready to fail to start the car unless I top up with a charger. Once topped up it works fine for a couple of weeks then i can feel a week start so I top the battery up again. Absolutely zero fault codes and sitting with new battery and new alternator now so totally stumped to why my battery is not keeping a 12.6 v charge! Anyone had the same problem? Thanks in advance for ant help. Andy
Threads: 123
Thanks Given: 250
34
Welcome.
I suggest checking that the battery is getting charged by testing with a multimeter while the engine is running, you should see about 14v DC. IIRC the battery positive terminal on the B9 is not visible, but there's a positive for charging / jump start point somewhere.
Threads: 5
Thanks Given: 4
21
Have a look at both of the battery connections and clean with wire wool/metal pot scourer and also find and clean the main earth connection to the body/engine.
You might also be draining the battery overnight by something drawing current - when you re-attach the battery leads look for sparking ( there may normally be a little ) - which would show that something is eating your electricity.
Threads: 41
Thanks Given: 129
9
(07-11-2021, 08:10 PM)oilyrag Wrote: You might also be draining the battery overnight by something drawing current - when you re-attach the battery leads look for sparking ( there may normally be a little ) - which would show that something is eating your electricity.
This happened to me on my M49 shortly after I bought it in 2001 - the battery kept going totally dead overnight. The dealer said it was the radio drawing off charge, so they fitted a new one under warranty, but it still occurred so they replaced the BSI, but it still occurred, so I just stopped using the radio and the problem stopped. Not an ideal solution and we never got to the bottom of the problem, though at the time it didn't seem a big deal to me to not use the radio, and that was certainly preferable to faffing around with the dealer and yet still coming out to a dead van every morning.
Threads: 5
Thanks Received: 2 in 2 posts
Thanks Given: 5
I had exactly this problem, turns out there is a free software upgrade as a recall from the dealer.
Been fine now for a year.
