  • 14 Vote(s) - 3.07 Average
Rotating wheels
No I don't mean round and round Smile but from LF to RR, RF to LR, etc. and do you stick the spare in the rotation sequence so you don't end up with four worn and an unused one collecting road grime. Just thinking of spring when I pull the winter tyres off and mount the summers. Only have four winter wheels but five summers if you include the spare. Cheers
Not as easy when the tyres are directional!
[-] The following 1 user says Thank You to zedhead for this post:
  • 3rensho
The advantage is even tread wear.
The disadvantage is buying 5 tyres at the same time.
Is usually put 2 new ones on the front and when the rears need changing put the recent fronts on the back and the new ones on the front. Think that makes sense...
That way you always have (slightly) newer tyres on the front as the front wheels (on a front-wheel drive) are doing the most work (driving,steering,braking) and you are only buying 2 tyres at a time.:woop:
I've been wearing out all my tyres out equally. The original Primacys still have nearly 4mm of tread on after 31k miles. I have swapped the spare across the back every 6 mnths & at about 15k I swapped the fronts to the back as the fronts were wearing slightly quicker. Another good reason for rotating spare regularly is that spare wheel carrier will eventually crack sidewall if tyre is not moved.
I shall replace all 5 when needed but with cheaper premium tyres than the Michelins.
My spare has its own little jacket and sits inside the van, not underneath (stupid idea).
http://www.ebay.co.uk/itm/150585228924?s...1439.l2649
Have also removed the spare wheel carrier (designed to lift off its mountings easily) and put it in the shed.
Can't believe manufacturers still put spare wheels underneath/outside to get wet, dirty, covered in salt and almost impossible to check the pressures.
Used to have a Volvo 340 many years ago; the spare was under the bonnet. Excellent idea.
And who remembers the Rover P6 with the boot-mounted spare...
Thank you all for the input. Now have to think over how/if I want to do this.
Yesterday 10:07 PM
Yesterday 10:01 PM
11-07-2026 12:02 PM
Berlingo 2026
11-07-2026 03:17 AM
10-07-2026 02:32 PM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
P1A9C
29-06-2026 06:05 PM
28-06-2026 03:35 AM
