Hi Berlinda, it's best to start a thread of your own, in the appropriate section which for your vehicle is the M49 area. Generally if it's a diesel, then there are some cleaners available like Redex, Wynn's injector cleaner etc which may help, their efficiency is generally 50-50 on opinion as to whether they work, or not.
My take on it is, Redex Diesel is pretty good, as is Wynns stuff - with the following caveat - if you need it, then it should help. If you didn't need it, then it will likely do nothing. That's to say if the system is full of wax and deposits, then it might produce a noticeable difference. If everything is still relatively clean, then it would not do much at all.
My quick example, I had a Honda Legend V6 3.2 24v motor which was really tickety-tappety when cold and even warm there was a noticable ticking at idle. The car was a beater, so I put a bottle of Wynns hydraulic tappet treatment in (which goes in the oil filler hole unlike fuel treatments), and it ran like silk after a couple of miles and never looked back.
Second time was a Subaru twin-turbo legacy which failed emissions at the MOT, I put a bottle of Wynns Emissions Pass in the tank and gave it a good run, turned up for the re-test MOT and it flew the emissions test. I did nothing else in between.
Just my personal experience. I find the Citroen diesels to run smoother and quieter with Redex Diesel in the tank, but I dose the tank with a full bottle to a full tank. 5th Gear did a rolling road test once on an old VW Sirocco VR6 trying Redex treatment etc and it did seem to return a lot of the lost power.
Opinions will differ - worth a shot for a fiver though.
Start a new thread here if you want to report back or discuss further:
https://www.berlingoforum.com/forum-9.html
Click the "Post Thread" button on the top right and go from there (after you open the link above).
