[Engine] Which timing belt for my 1.6 petrol?
Hi!
I got a problem, i got a 2005 Berlingo Multispace with the 1.6 petrol.
I need to change the timingbelt but have two options:
One is: to engine number 1806404
One is: from engine number 1806405
I think i found the engine number on the block reading: 306600 but that dont match any of the numbers above.
Can someone help me?
The V5 will give engine number
Change pump and aux belt as well
(15-11-2021, 09:09 PM)geoff Wrote:  The V5 will give engine number
What do you mean with V5? (im from Sweden) Smile
(15-11-2021, 09:10 PM)geoff Wrote:  Change pump and aux belt as well
Yes, i will change everything. But dont know which kit that fits...got two to choose from!
I had the same problem with my 2007 Peugeot 307 1.6 petrol (same engine). I can find my engine number tomorrow as I cannot go to the car now. I bought the Gates KP15581XS timing belt kit with the whole set with the water pump, etc. from autodoc. Fitted perfectly. I vaguely remember that my engine number was somewhat similar to yours, way too short of the numbers.
EDIT:
The belt is the same in both, only the pulleys are different!
engine N since 1806405 is belt for example Gates 5581XS (PSA part N 0831R9) Gates kit K025581XS
engine N till 1806404 is belt for example Gates 5581XS (PSA part N 0831V1) Gates kit K015581XS
I think I bought the kit and everything was fine, apart from the roller/guide pulley which was totally different (a few mm wider) and I had to buy it separately.
Hello Johan I diddn't see you were located in Sweden, apologies !
In the UK the V5 is the vehicle registration document that contains details of the registered keeper, the vehicle chassis number / VIN number and also the engine number.
EDIT:
Yes! I saw this about the pulleys! What should I do? Haha
Even if you have to buy the guide pulley separately, as I did, it was only ~£14.
I managed to check my engine N. It is A1433039 (photo attached)
Higher than yours, but below the first given in the numbers.
I bought the set below the 1806404 (Gates KP15581XS). The tensioner and the belt were spot on, only the roller was not. I bought the TINA roller, similar to this febi one: https://www.ebay.co.uk/itm/234224759437
The ebay roller was specific to my car, but yours might be ok with the original Gates (or other) sets.
MOT Emissions repeated fail
Last Post: Marsaday
Today 10:41 AM
Rear door filling with water
Last Post: Marsaday
22-01-2026 04:37 PM
Last Post: rom4ik
20-01-2026 04:11 PM
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
