Lost 5th gear
Good evening all,
2016 1.6 HDI adblue 75hp Berlingo 55000 miles
I have recently lost 5th gear completely.
I removed the gearbox end inspection plate, to find bits of what looks like the 5th gear sunchro hub
I am guessing of course as I know nothing about gearboxes.
Can this be repaired in situ without removing the gearbox?
Anyone know what parts i need?
Attached Files Thumbnail(s)
with these broken bits floating around the gearbox it may be better to try another gearbox than try to fix this one.
A second hand g/box may be about the same price or cheaper than the parts you will need if you can get them.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
  • colinsulby
It looks as though repair kits are available, which might suggest that it can be repaired 'in situ'?
https://www.ebay.co.uk/itm/183283097787?...%3A2047675
And YouTube may have a guide if you search?
  • colinsulby
any ideea why this happened?
If you like gaming visit GameForest
(22-11-2021, 07:13 AM)deejay_xb Wrote:  any ideea why this happened?
No idea, the van doesnt get any abuse at all.
Thanks for the replies and the ebay links guys,
after looking at some youtube videos I might actually have a go at this repair myself.
I will keep you all posted.
Engine Fan Running
04-12-2025 11:07 AM
Last Post: SonofaGun
02-12-2025 10:51 PM
02-12-2025 06:14 PM
Rear view mirror
02-12-2025 08:19 AM
Gear number display
Last Post: MarcoLingo
29-11-2025 09:02 AM
25-11-2025 04:20 PM
Lapik's 5-th Berlingo
25-11-2025 08:21 AM
ë
24-11-2025 09:08 PM
Welding precautions
24-11-2025 12:37 PM
driveshaft tripod joint spring
24-11-2025 12:31 PM
