1.6i 16v, transmission oil leak?
Hi!
I got a 2005 Petrol 1.6.
It leaks very little from center of bell housing. Can the drive shaft seal leak into the bell housing causing this or is there a seal in the transmission itself behind the bearing? Is this common?
Depends whether the oil dripping out is engine oil or transmission oil - the crank seal at the flywheel might leak and the input shaft seal in the gearbox might leak - both will end up dribbling into the bell-housing and out of the lowest point. Either would be a major job to sort out, so if the leak is not significant, best left alone!
Transmission oil is often smelly - so that might help to identify the source.
Warranty on parts
Yesterday 04:17 PM
Ahh bless them...
06-08-2026 02:28 PM
06-08-2026 07:34 AM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
Check this one out guys
04-08-2026 10:01 PM
04-08-2026 11:30 AM
02-08-2026 02:22 PM
Berlingo 2026
Last Post: xtimex
29-07-2026 03:34 AM
