Internal roof rails
Hi all
Does anyone know of how to get some internal roof bars for my berlingo?? I need to hang bike helmets and jackets to dry.
Thanks all
The official ones cost a small fortune from the dealers and are also usually very expensive on the like of ebay as a result.
If you dont require the increased depth that the official ones provide then you can do as I have done and use a telescopic washing line pole (with the hook cut off) or a telescopic shower rod and just extend them onto the cavities provided in your vehicle.
[-] The following 2 users say Thank You to Daveyboy for this post:
  • Kenners009, Marc S
(23-11-2021, 05:34 PM)Daveyboy Wrote:  The official ones cost a small fortune from the dealers and are also usually very expensive on the like of ebay as a result.
Yeah I saw the 169 price tag for the proper ones..
I.might give that a whirl as don't need the depth just some extra storage up there
Thanks for the ideas
In this much earlier post you'll see how I used the internal roof rack fixing points to provide cargo anchoring points which I use for holding bikes in place but can be used for anything. https://www.berlingoforum.com/thread-13929.html
Matt
   previous
   2016 1.6 HDi 100 XTR Grey Met
   2010 1.6 HDi 105 XTR Gold Met
Several sets of original bars available on Facebook Marketplace - Ranging in price between expensive and extortionate  Confused
 https://www.facebook.com/marketplace/109...oof%20bars
(24-11-2021, 02:59 PM)Daveyboy Wrote:  Several sets of original bars available on Facebook Marketplace - Ranging in price between expensive and extortionate  Confused
Oh yeah there are some. Thanks for that.
They are definitely costly
M8 hex boltheads fits pretty snugly in the mounting points, so if you put one in each ond of a telescoping rod, you're all set.
(26-11-2021, 02:22 PM)Gadgetman Wrote:  M8 hex boltheads fits pretty snugly in the mounting points, so if you put one in each ond of a telescoping rod, you're all set.
ill grab some of those and give it a try.
thanks for that
(23-11-2021, 03:49 PM)Kenners009 Wrote:  Hi all
Thanks all
I used a £1 IKEA curtain rod that came with threaded inserts already in the end (M5 i think) and used a washer and a nut on a bolt to attach to the slot under the cap. it retracts to 700mm so can be stored easier.
here is the link to the curtain rail i used - https://www.ikea.com/gb/en/p/raecka-curt...-70221395/
I have attached some pictures for reference
Hope this helps and cant go wrong for £1 plus 2 bolts 2 nuts and 2 washers!
Attached Files Thumbnail(s)
[-] The following 1 user says Thank You to Snels for this post:
  • cancunia
+1 for expanding rod which is what I have, net curtain wire for light items.
08-06-2026 11:13 AM
Last Post: TGD
06-06-2026 09:50 PM
06-06-2026 12:29 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
