Tightening Torque explained
Hello all,
I was just looking through the B9 service manual as I am going to attempt repair of my 5th gear problem myself.
Can someone explain what the French tightening torques mean in standard NM?
Tightening torque
(15)
Secondary shaft nut
6,5 daNm
(16)
Primary shaft nut
7,2 daNm
(24-11-2021, 01:08 PM)colinsulby Wrote:  Hello all,
Tightening torque
(15)
Secondary shaft nut
6,5 daNm
(16)
Primary shaft nut
7,2 daNm
Have a look at this thread: https://www.berlingoforum.com/thread-19908.html
I had the same question. Basically, 1da.Nm = 1m.daN = 10Nm
So, your 6,5 daNm == 65Nm
As above, and this might help https://www.convertunits.com/from/daN/to/newton
Brilliant guys, thank you very much.
Today 01:49 PM
Yesterday 10:07 PM
11-07-2026 12:02 PM
Berlingo 2026
11-07-2026 03:17 AM
10-07-2026 02:32 PM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
P1A9C
29-06-2026 06:05 PM
28-06-2026 03:35 AM
