Bonnet edge flexible seal, what material is used?
Hi All,
As per the title, do you know what is the flexible and pretty hard material that is used on the inner (front) edge of the bonnet?
I have a slight surface rust just under the seal and in order for this not to grow I have to address it. I was planning on cutting half of it, sand/prime/paint and apply a similar seal. Seems like Sikaflex 221 could be applied, but was wondering if there is something else.
Many thanks for any suggestions.
Have you contacted Citroen? Someone there must know.
(27-11-2021, 09:04 AM)notsofast Wrote:  Have you contacted Citroen? Someone there must know.
Good suggestion, although I never had any luck whenever I contacted them.
07-02-2026 05:42 PM
heater down
05-02-2026 04:49 PM
Rear seat belt breakage
02-02-2026 02:34 PM
High mileage vehicles ?
Last Post: chrisl
01-02-2026 09:22 PM
Berlingo rear suspension
Last Post: Geordie graham
01-02-2026 01:13 PM
Last Post: chrisl
29-01-2026 07:06 PM
28-01-2026 09:18 PM
Cheap(er) oil
28-01-2026 03:39 PM
28-01-2026 06:13 AM
Last Post: Big_Jim1967
27-01-2026 08:32 PM
