Rear brake compatability
Hi, Folks
new to the forum, have bought a scrap 2007 1.6 HDi van which appears not to have ABS, but has a good rear axle to swap over onto my 2006 1.9D van, which has ABS but a snapped torsion bar.
Is there any difference between the rear brake set up, or is it a straight swap?
TIA
There shouldn't be any difference if they are both disc which I think they should be.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
A lot of the M59's used rear drums with their ABS system, I think disc were only used if the vehicle had ABS & ESP (Electronic Stability Programme)
If it is on drums it should just be a case of swapping the drums from the old (original) axle to the new axle, as I believe the axles are all the same.
(25-11-2021, 01:49 PM)jj9 Wrote:  A lot of the M59's used rear drums with their ABS system, I think disc were only used if the vehicle had ABS & ESP (Electronic Stability Programme)
Job done, all brakes swapped over no bother, including abs hubs and sensors.
Thanks, Folks
[-] The following 1 user says Thank You to BingoB for this post:
  • jj9
Last Post: Muppets on Mars
Today 10:48 AM
Last Post: JPCoetzee
Yesterday 03:52 PM
OIL Drip
Yesterday 01:49 PM
Yesterday 01:42 PM
10-03-2026 10:47 PM
10-03-2026 09:14 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
09-03-2026 05:17 PM
