From 1st to 3rd gear it drives reasonably OK, but once I build up speed and go over 3rd gear it struggles and chucks out black smoke
I checked the egr valve and filter and i see no obvious problems. Any ideas would be appreciated
Thanks Jamie
Threads: 41
Thanks Received: 82 in 75 posts
Thanks Given: 129
9
Injector problem?
Threads: 7
Thanks Received: 3 in 3 posts
Thanks Given: 7
Possibly a blockage or restriction in the engine air intake?
Threads: 123
Thanks Given: 250
34
Black smoke suggests over fueling, maybe the inlet valves are not opening enough? Have you checked the valve clearances?
