Threads: 3
Thanks Given: 1
Hi, I have just bought a 2020 Berlingo but I am worried as occasionally there is a flashing orange light at the bottom right of the rev counter. It happens too fast for me to read the symbol. Can anyone help? Thanks
Threads: 19
Thanks Received: 31 in 30 posts
Thanks Given: 12
16
29-11-2021, 05:54 PM
(This post was last modified: 29-11-2021, 06:02 PM by Mark604.)
Is that the lane departure warning light? Does it happen when the steering pulls a little?
If it is, you can switch it off. If you do, the light will stay on all the time and then you can see if it is the one you mean.
https://www.youtube.com/watch?v=yvIqSxXC...ABnIreland
Now a 2019 K9 1.2 petrol.
Threads: 23
Thanks Given: 46
5
It could be the change up a gear advice?
Threads: 27
Thanks Received: 15 in 14 posts
Thanks Given: 9
This sounds like the lane departure warning which flashes if you stray too close to or cross over the white lines. If you press the button below the headlight height adjuster to the right of the steering wheel you can deactivate it. It will automatically reactivate upon restart though. I find it a total pain in the arse if im honest. If you are on a road with narrow lanes it goes almost constant.
Threads: 20
Thanks Given: 7
15
You can also turn it off in the car settings menu - its great at night but a real pain where for example there is road work and it picks up the old lane markings!
Threads: 11
Thanks Received: 31 in 31 posts
Thanks Given: 3
7
Not sure it should be a problem at road works as it should only operate above 40mph.
Geoff
Threads: 19
Thanks Given: 12
16
"You can also turn it off in the car settings menu."
Never seen that setting in mine. Not saying it's not there, just never come across it.
I also think it's difficult to live with if activated all the time. My start up procedure involves immediately switching it off.
Threads: 2
Thanks Received: 56 in 52 posts
Thanks Given: 38
8
Some models have a button, some have a menu entry.
ex: 2003 1.4i cargo
