[Engine] Lack of power
Hi everyone I need your wealth of experience I have a 61 plate 1.6 and I’m struggling to find what’s wrong with it. It probably started about a year ago when very rarely I would start it and there would be no power at all even when you push the accelerator down turn off ignition and then fine for weeks unfortunately this now happens several times a day!!! The EML has come on with a few codes egr valve related also pre heater relay. I have had the egr changed but has made no difference at all the codes have been cleared but the fault remains the only thing that shows up on my cheap diagnostic is the pre heater relay but not showing a EML on the dash. Once it’s has started sometimes after several attempts it can run fine or more recently had started going into this total lack of power mode ( not a proper limb mode as there are no revs at all ) when the revs drop. Other things that might help with diagnosis is it always happens when I put it in reverse!!  for some reason and the fuel consumption has reduced slightly and no real smoke to mention from the exhaust.
I would be  very grateful of any suggestions.
Attached Files Thumbnail(s)
(03-12-2021, 05:57 PM)Philthefish Wrote:  Hi everyone I need your wealth of experience I have a 61 plate 1.6 and I’m struggling to find what’s wrong with it. It probably started about a year ago when very rarely I would start it and there would be no power at all even when you push the accelerator down turn off ignition and then fine for weeks unfortunately this now happens several times a day!!! The EML has come on with a few codes egr valve related also pre heater relay. I have had the egr changed but has made no difference at all the codes have been cleared but the fault remains the only thing that shows up on my cheap diagnostic is the pre heater relay but not showing a EML on the dash. Once it’s has started sometimes after several attempts it can run fine or more recently had started going into this total lack of power mode ( not a proper limb mode as there are no revs at all ) when the revs drop. Other things that might help with diagnosis is it always happens when I put it in reverse!!  for some reason and the fuel consumption has reduced slightly and no real smoke to mention from the exhaust.
That is a strange one.
The glow plugs/relay would not give you a lack of power, but you may want to test the glow plugs with a mutlimeter for continuity or resistance (one end on the tip of the glow plug and another on the block of the engine). If one is duff you could replace it. It could well be that the relay is gone, but I doubt it.
When replacing the EGR, it is usually good to recalibrate it. It is done with Diagbox/Lexia. Usually a bad EGR will give you rough idle, etc., rather than low power. To eliminate the lack of power with the EGR you could blank it and see if anything changes.
Thanks for that I was told the egr didn’t need recalibrating but will look into it.
Is this not a possible electrical or BSI issue?  If the EGR or glow plugs aren't working properly, that shouldn't result in total lack of power, particularly in the sporadic and erratic way as described.
BSI what it that notsofast?
It's the central computer that manages and integrates the electrical systems. It might be thinking there's a fault when there isn't one (other than a fault within itself).
Ok thanks have just looked up re set on YouTube
The engine will move slightly when put into reverse so could the engine wiring harness be loose where it plugs in ?
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Can doing a BSI re set when there isn’t an issue with it cause a problem?
Last Post: TGD
Yesterday 09:50 PM
Yesterday 12:29 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
Mark 3 camper van conversion
Last Post: minkybeau
23-05-2026 07:38 AM
