Threads: 3
Thanks Given: 1
Sorry if this has been asked before - I'm new on here.
My 06 plate car occasionally has a random triple bleep warning sound with no indication of what's triggering it.
Its the same triple bleep if you open a door with the engine running, but in this case the central display doesn't bat an eyelid.
Tried the main dealer, but they've no idea.
Anyone else had this?
Threads: 147
Thanks Given: 263
11
Is the berl moving what is makes the noise, or should I say what is the car doing when the noise goes off?
Threads: 32
Thanks Given: 13
Is the air bag light on?
It also does the triple bleep when the fuel gauge reaches the last 10 litres or so. Is it coinciding with low fuel??
Threads: 147
Thanks Given: 263
11
I first thought it might have been your seatbelt warning. Will have a think. If it is never solved might be worth someone looking at all the possible warning alerts settings in Lexia, as they can be turned on and off from there and assuming it is a standard alert, it should be listed.
Threads: 101
Thanks Received: 276 in 220 posts
Thanks Given: 384
Fuel light, keys in with door open, lights left on, handbrake on when moving...
Citroen like to entertain us.
Threads: 3
Thanks Given: 1
No its a slightly different note to the "keys left in" but yes its the same tone as low fuel, even with a full tank.
Will try the handbrake to see if its the same.
Threads: 17
Thanks Received: 14 in 10 posts
Thanks Given: 6
Or have you put a bag or summat on the pass. seat ?
'98 D 800 van
