Threads: 42
Thanks Received: 409 in 366 posts
Thanks Given: 137
31
Sounds like a bad connection somewhere. As you have changed the starter which should have a solenoid mounted on top it is the solenoid which is doing the clicking. Its in the area of the clicking sound.
If you are sure its a good starter motor then it could be a bad connection at the engine earth strap.
A bad connection will heat up when trying to start.
The battery earth (negative) connections where it connects to the body is another area which may need to be looked at.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Threads: 5
Thanks Given: 4
21
Might the ignition switch be the problem as you've changed battery & motor? The solenoid has to move the full distance to make contact with the supply lead internal contact and I wonder if there is a weak supply from the ignition switch. With ignition off if you take off the small lead from the motor and use a fly lead from the battery and touch it on the now exposed small lead contact it should drive the motor straight away. Make sure that you are in neutral or Park otherwise the vehicle will move.
Alternatively remove the motor and do the same test on the bench.
Good luck!
Threads: 2
Thanks Received: 1 in 1 posts
Thanks folks. Found the negatice battery connection was just a little bit loose. Cleaned up the terminal and tightened properly. Starts first time now . . Pleased as Punch !! Thanks so much for the suggestions
The following 1 user says Thank You to manxblue for this post:1 user says Thank You to manxblue for this post
• dogen
Threads: 11
Thanks Received: 32 in 32 posts
Thanks Given: 3
7
Hi
That's good.
It is always better to start with the basics before getting into the complicated.
Geoff
The following 1 user says Thank You to Guanock for this post:1 user says Thank You to Guanock for this post
• dogen
Threads: 5
Thanks Given: 4
21
I guess that you may be talking of the earth connection on the car rather than the battery earth. Just follow the large negative lead from the battery to the terminal. If you don't want to risk having to re-set anything caused by disconnecting the lead then attach a jump lead from the battery terminal to the chassis or engine block to maintain the circuit, before any disconnections.
