Can I use a heated wing mirror on a non heated wing mirror van?
Hi, I have a Citroen Berlingo enterprise 100. I had my wing mirror smashed off today and need a new one. All I can find online is ones with the heated function. I was wondering if they will still fit to my no heated van or if I have to get one with no heater function on it?
Thanks lee
I dont think there will be a lot of difference between the heated mirror and non heated. There will be heating elements on the glass and extra wires but I think that will be all , the fitting should be the same.
Someone else may know better
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
(09-12-2021, 08:21 PM)brodfather11 Wrote:  I dont think there will be a lot of difference between the heated mirror and non heated. There will be heating elements on the glass and extra wires but I think that will be all , the fitting should be the same.
Thank you Smile
IIRC, the difference is that there are simply 2 spade connectors on the heated version vs the non heated version.
(10-12-2021, 09:21 AM)cancunia Wrote:  IIRC, the difference is that there are simply 2 spade connectors on the heated version vs the non heated version.
Will it be fine to just leave the heater connect unconnected then? Thanks a lot
Yes, the heating function is controlled within the cab, not within the housing. IIRC the only wires going into the housing are for the element- so if there are no wires you cant connect them.
Vlad
Warranty on parts
Yesterday 04:17 PM
Ahh bless them...
06-08-2026 02:28 PM
06-08-2026 07:34 AM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
Check this one out guys
04-08-2026 10:01 PM
04-08-2026 11:30 AM
02-08-2026 02:22 PM
Berlingo 2026
Last Post: xtimex
29-07-2026 03:34 AM
