Berlingo Dash/Stereo
Hi, new to the forum hopefully this post won’t be classed as a fault if I’ve posted incorrectly I’ll apologise now.
Just had quick question about the berlingo head unit and the storage bit underneath it.
I’m wondering if it possible to swap them around? I’d like the storage bit on the top and the head unit just about the heater controls etc….
My reason is I’ve been bought a dab adapter and I dnt really want to attach it to the dash and drill the dash so I can swap the storage bit around I’d attach it to that as it can be removed and I think it’s better to drill something I can change if needed in the future than leave holes in the dash
Hopefully this makes sense
Dan
Welcome.
It might depend on what year / model Berlingo you have but my guess is the answer will be no as the radio head unit is held in place partly from behind by a steel bracket.
Generally, the radios are easy enough to get out and take a look.
  • Danharry
Answering my own question incase anyone else has the same idea, but had a little play this evening and yes it can be done, need to disconnect the cables and swap them round as there’s a plastic bar between the unit and storage bit. Little bit fiddling sorting the cable but eventually fitted in nice ?
(09-12-2021, 08:31 PM)Danharry Wrote:  Answering my own question incase anyone else has the same idea, but had a little play this evening and yes it can be done, need to disconnect the cables and swap them round as there’s a plastic bar between the unit and storage bit. Little bit fiddling sorting the cable but eventually fitted in nice ?
Glad you got it done.
What year / model Berlingo do you have?
I’ve got a 2010 swb. The new style of that makes senses I’ll add a few pics once done the dab upgrade
Last Post: LucyLeBingo
Yesterday 02:42 PM
Yesterday 02:30 PM
Last Post: jw4821
Yesterday 12:53 PM
Coolant
Last Post: tomhick024
19-04-2026 06:18 PM
SOLVED: P20F6 fault
19-04-2026 08:28 AM
Leaking windscreen or aerial
15-04-2026 08:50 PM
