[Engine] Misfire and cutting out
Right, my 1.4 petrol van is still giving me issues. I changed the crankshaft position sensor because it wouldn’t start, and while I was under the bonnet I changed the spark plugs and coil pack. But it’s misfiring occasionally, feels like it’s losing a cylinder for a few seconds then it chimes back in.
Now in all fairness the parts I bought were cheap pattern parts so there’s a possibility they could be faulty straight out of the box, but is there anything else I can take a look at? I’ve checked the fuel pump and filter and they’re fine.
Also, ever since I bought this van it cuts out when you reverse and the dashboard bleeps, but I’ve have a diagnostic kit on it and I can’t find any reason. Any ideas?
Any especific error on the diagnostic tool?
It has a fuel pump right? If yes try to do some tests, is just an advice.
When it cuts out when reversing does it start right away ? .Or do you have to select a forward gear before it will run?
Any dash lights with the beeping ?
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
(12-12-2021, 06:09 PM)SergioFR Wrote:  Any especific error on the diagnostic tool?
There’s no errors at all, and the fuel pump works perfectly. I’ve tested it thoroughly, and all the petrol is fresh, I completely drained the tank recently.
(12-12-2021, 06:31 PM)brodfather11 Wrote:  When it cuts out when reversing does it start right away ? .Or do you have to select a forward gear before it will run?
So I reverse and when I brake at the end of the manoeuvre the engine stops and I get a single warning bleep. No lights showing. And it starts up again first touch of the key. I can’t work it out.
Yesterday 04:48 PM
Last Post: BrianS
Yesterday 01:58 PM
» Replies: 24
Drop in fuel economy
Last Post: Andhall
Yesterday 09:21 AM
Not able to register
Last Post: Mike
22-01-2025 11:03 PM
2011 B9 DPF warning light
22-01-2025 10:51 PM
Last Post: Matt Haigh
22-01-2025 07:21 PM
M59 rear wheel splay...
21-01-2025 03:27 PM
Indicator/lights Stalk
Last Post: magoo1
21-01-2025 03:09 PM
Last Post: pondweed
21-01-2025 01:21 PM
21-01-2025 12:41 PM
