Threads: 21
Thanks Received: 4 in 4 posts
Thanks Given: 16
I will be replacing the battery on my 2010 Multispace 90 HP Diesel.
Can I just remove old battery, fit new battery and start it up or is there a procedure I need to follow? Do I need any code numbers or will I need to have codes reset?
2010 Berlingo Multispace 1.6HDi - Chipped
Threads: 123
Thanks Given: 250
34
12-12-2021, 03:44 PM
(This post was last modified: 12-12-2021, 03:45 PM by cancunia.)
I think that so long as you leave the bonnet open with keys out & doors closed for about 5 minutes so all the systems are shut down, before disconnecting the old battery, you should be fine. In case you've not already got a new battery, I've found Tayna to be the best & cheapest, you just need to look down through the listings as they put their preferred items at the top of the list & you can't sort on price.
Threads: 5
Thanks Given: 4
21
Might you need the radio code?
Threads: 21
Thanks Given: 16
12-12-2021, 05:41 PM
(This post was last modified: 12-12-2021, 05:43 PM by old son.)
Thanks for your responses. I purchased from Tanya and rightly or wrongly chose a 78ah battery rather than a 70ah. I think the CCA figure was higher too.
Threads: 67
Thanks Given: 238
50
A battery with higher AH and CCA figures is only going to be a bonus.
Serieal Berlingo owner
Threads: 21
Thanks Given: 16
(12-12-2021, 05:45 PM)geoff Wrote: A battery with higher AH and CCA figures is only going to be a bonus.
All changed and running/starting fine. Thank you for your help
