Calibrating new EGR??
Hi everyone.
Berlingo Multispace B9, 2008, 1.6HDi, 90hp 66kw, 220.000km
I will change my faulty EGR valve with a new one in a couple of days.
Do I need to calibrate the new EGR after installing it?
If yes, how can I do it?
Are there any other things that I should be aware of when doing this operation?
Cheers
Oliver
(13-12-2021, 12:09 AM)OliverMy Wrote:  Hi everyone.
Cheers
Oliver
Yes, you should recalibrate it through Diagbox/Lexia. It is pretty straight forward and the software will guide you through the procedure, it is mainly switching the ignition on and off a few times. Mine is a Pug Partner (1.6HDi 2007), so could not quite comment where in the Lexia menu is the EGR recalibration. I doubt it is of much help, but here is my Diagbox/PP2000 way to recalibrate it: https://youtu.be/0s39tfitoso
At least with the Diagbox/PP2000 it is in the replacement parts->ignition system-> then engine N
Last Post: Beaumotor
Yesterday 04:38 PM
engine light
Yesterday 09:25 AM
M59 1.4 Petrol question
19-03-2025 06:12 PM
Cold Starting
Last Post: jboy012000
18-03-2025 10:46 AM
17-03-2025 08:12 AM
2015 Berlingo van for sale
Last Post: eddyale
16-03-2025 06:47 PM
Last Post: deejay_xb
16-03-2025 02:53 PM
» Replies: 29
2.0 HDI. engine won't start
16-03-2025 01:48 PM
Unusual Braking Problem
16-03-2025 07:52 AM
valeo alternator CL15 rebuild
16-03-2025 07:49 AM
